Engine Cranks dose'nt start
Posted 08 August 2009 - 11:23 AM
when was the last time the truck was tuned? have you checked to see if you have spark at plugs?
I tuned it about a year ago, I just checked this am 8/8/09 and i have no spark,i removed spark plug and grounded it on block and saw no spark, could it be my coil??
Posted 09 August 2009 - 08:10 AM
I just replaced the ignition coil and my truck started right up, i wasnt geting fuel so i changed the inline fuel filter so all is GOOD
Posted 18 August 2009 - 04:23 PM
if it happens again check your points (if you still have them) with a feelier gauge and make sure it reads .017 otherwise u wont get any spark.
Edited by Ol Nellie, 18 August 2009 - 04:26 PM.
Posted 21 October 2009 - 08:32 PM
Check to see if your feeding the coil around 9V. Just to be sure. 12 volts will take out the coil and wear out the points. Needs a resistance wire.
Geese I need to look at the date!!!
Edited by Kennewick, 21 October 2009 - 08:35 PM.
4.9 FI I6
ZF542 spd OD
355 gears
17.5 mpg mixed driving
