96 F350XL Vacuum Lines Diagram
f350 vacuum
2 replies to this topic
#1 redfalcon
redfalcon
  • Favorite F-Series Year?:1996
Posted 20 June 2016 - 07:51 AM
Hi everybody. I am new to this forum so please forgive me if I make any mistakes.
 I bought an F350XL 1996 and took it to the mechanic who replaced the engine (Actually he made an engine out of two broken engines). Anyway when I picked up the truck he said that he had problems with the vacuum lines since he didn't have a diagram and does not where exactly they go. This is supposed my work truck and I am stuck because it keeps shutting off when idle. My mechanic said he still looking for a diagram but not avail. Can anybody please help me with this issue? Anywhere I can get the diagram for? Do you think he is lying on the reason why it keeps shutting off?
Thanks!
Gio
#2 miesk5
miesk5
    F-Series Maniac
  • Moderators
  • PipPipPipPipPip
  • 145 posts
  • Interests:Broncos, beach runs, surf fishing
Posted 21 June 2016 - 05:58 AM
Yo,
Welcome!
Stop by local Ford dealer parts dept. & ask for
Vehicle Emission Control Information (VECI) Decal,have VIN with you.
Contains the Vacuum Diagram for you F350.
Here is a sample;
http://www.diesel-da...ges/a10418g.gif
Item Part Number Description
1 Adjustment Procedure Notes
2 Ignition Timing Specification
3 Engine Vacuum Hose Routing (Typical)
4 Spark Plug Gap Specification
5 Engine Type
Yes, major vacuum leak Will Cause a rough idle or stalling.
Btw, 96 Bronco-F-Series Workshop Manual (PARTIAL) by FORD at http://www.diesel-da...stj/stjleft.htm
Recalls; check with VIN at dealer or on-line @ Ford; esp. Speed (aka Cruise) Control recall; this recall has a life of its own and still undergoing changes; deals w/speed control deactivtation switch mounted on master cylinder; fires have been reported.
https://owner.ford.c...v=footer-owners
Also, register to see any Ford dealer maintenance/repairs done @ any dealership nation-wide.
Also, feel free to join our sister site at http://broncozone.com
Owned by same folks, Jeff's Bronco Graveyard
96 Bronco, E4OD, Man Xfer Case & Hubs
See my Big Bronco & F Series Technical & Parts LINKS site. Will need to clean up dead links & add many more new links some day. Thanks to Mr. Schwim! http://schwimserver5.com/?index=1128
Thanks to All Who Serve
#3 miesk5
miesk5
    F-Series Maniac
  • Moderators
  • PipPipPipPipPip
  • 145 posts
Posted 21 June 2016 - 07:38 AM
Yo,
What engine?
This is not the Ford vehicle diagram! But a version by all-data
For 7.3 diesel
http://www.thediesel...45&d=1244688073
If not opening see http://www.thediesel...em-diagram.html
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
