Bronco Coil Spring Replacement?
Posted 27 June 2004 - 05:41 AM
Raise the front end by the frame (to take the weight off the springs), take the tires off, use a spring compression tool and start to compress. Unbolt the spring locks on the top and bottom then compress the spring enough to pull it out. Repeat the process in reverse to install.
Am I missing something or is it that simple? I know I will need to do both sides.
I was planning to go off-roading this weekend until I saw the passenger side spring was broken. You can see the part of the top coil hanging at the top left side near the yellow shock.
http://home.nycap.rr.com/albany4x4/images/Local%20Rigs/Darrin's%20Bronco/Broken/PassSpring.jpg
Police Package
351W
E4OD
31" Tires
Posted 27 June 2004 - 09:39 AM
The proceedure is as follows (from the Ford shop manual)
Removal
1. Raise the vehicle and remove the shock absorber to lower bracket attaching bolt and nut.
2. Remove spring lower retainer attaching nut from inside of the spring coil.
3. Remove spring upper retainer attaching screw and remove the upper retainer.
4. Position safety stands under the frame side rails and lower the axel enough to remove the tension from the spring.
Note: the axel must be supported on the jack throughout the spring removal and installation,and must not be permitted to hang by the brake hose. If the length of the brake hose is not sufficient to provide adequate clearancefor removal and installaation of the spring, the disc brake caliper must be removed from the spindle. After removal, the caliper must be placed on the frame or otherwise supported to prevent suspending the caliper from the caliper hose. The precautions are absolutely necessary to prevent serious damage to the tube portion of the caliper hose assembly.
5. Remove the spring, lower retainer, and lower the spring from the vehicle.
Installation
1. Place the spring in position and slowly raise the front axle. insure spring is positioned correctly in the upper spring seat.
2.Position the spring lower retainer over the stud and lower seat and install attaching nut (torque to 94-134 N-m , 70 - 100 ft. lbs.).
3. position the upper retainer over the spring coiland install the attaching screws (torque to 18 - 24 N-m, 13 - 18 ft. lbs.)
4. Position the shock absorber to the lower bracket and install the attaching bolt and nut with the bolt head towards the tire. Tighten the bolt and nut to
66 - 88 N-m , 48 - 65 ft. lbs. Remove safety stands and lower the vehicle.
You might want to replace the insulator bushing between the upper and lower spring seat while you are at it.
Walla!! youre all done.
Posted 27 June 2004 - 05:52 PM
Next problem I am having is do I want to just get the springs now then in a month or so get the shocks then four months or so get a 6" lift kit and have to replace all of that again.
I am thinking I should wait and save my money to get the lift.
Idea on cost hear in NY...
Springs $72.09
Shocks $50.00 ea. X 6
Almost $400.00
eBay cost for a lift kit $645.50ish
Difference $245.50
Almost makes sense to wait and get the lift.
Real question, is it safe to run normal street driving with that broken spring?
Police Package
351W
E4OD
31" Tires
Posted 27 June 2004 - 06:32 PM
If you need a replacement spring to get you rolling, check the junkyards. I also have a spare set of stock coils from my 84 that you can have for shipping cost.
Posted 27 June 2004 - 07:14 PM
Posted 27 June 2004 - 07:16 PM
I am looking at...
Rough Country 4" lift $449.00
Upgrade to 6" $ 54.00
Quad Suspension $ 56.00
Shock Boots (other than Black) $ 12.50
Shipping $ 74.00
Total cost $645.50
Kit contains...
- New variable rate front coil springs
- I-beam and radius arm drop down brackets
- new drop pitman arm to correct steering
- 3" block and u-bolt kit for the rear
- a heavy duty STEERING STABILIZER is included as well as mounting kit
- four 8000 series shocks
- 5 black shock boots
- all necessary hardware which is zinc plated and complete instructions
This is why I love this board, I know some things with the Bronco but other things I don't know much about and I can always count on someone having the right answers
Thanks
Police Package
351W
E4OD
31" Tires
Posted 27 June 2004 - 07:20 PM
Yah that nut is a little tricky to get at. You have get a socket on it and move the ratchet along the inclined plain of the coil. That might not make much sense now, but when you get to doing it you will see what I mean.
Posted 27 June 2004 - 07:37 PM
Thanks
Police Package
351W
E4OD
31" Tires
Posted 30 June 2004 - 05:40 PM
#11
Posted 01 July 2004 - 02:50 AM
I will be taking pics as I do it so everyone can see how it goes.
Police Package
351W
E4OD
31" Tires
#12
Posted 01 July 2004 - 07:21 PM
#13
Posted 02 July 2004 - 02:56 AM
The place I am getting the kit from says I may need the front brake lines. I have been having a small problem with my tires hitting them when turning at full lock, does this mean I am ok with them or do I need the longer ones?
Police Package
351W
E4OD
31" Tires
#17
Posted 02 July 2004 - 06:09 PM
#19
Posted 03 July 2004 - 03:03 AM
Police Package
351W
E4OD
31" Tires
#20
Posted 06 July 2004 - 08:09 AM
