I need some advice. I have a project Bronco, '85 w/ Cummins/47RE/NP241. While re-wiring the rear glass, the glass broke! I got a new one from the local salvage yard, it was in a pile, but marked '82-'96, so I think it's the right one. The problem is that the glass stops moving about 2-3" from the top. I checked the glass movement with the tailgate down, and It moves all the way up. I also removed the wheatherstipping and pushed the glass rearward while putting it up, and it went all the way up. It seems like the glass is too wide (side to side) for the top. Any suggestions on a fix before I break out Mr. router and 'alter' the weatherstripping's channel??
Rear Glass Woes!
Wliebhard
, Jul 06 2004 11:49 AM
Posted 06 July 2004 - 03:03 PM
First of all, Welcome to the B Zone! <' />
The window should fit without ripping up the weatherstrip.
Do a search for tailgate compatibility here on this board, someone posted that question and there was something with the adjustments and the rear window.
I think it is a simple adjustment fix. There is a link in that post that will show the differences between the years for the tailgate and rear window.
Maybe the gate isn't closing all the way, that will cause your problem as well.
90 Bronco Full Size
Police Package
351W
E4OD
31" Tires
Police Package
351W
E4OD
31" Tires
