Dash Center Section
9 replies to this topic
#1 Wliebhard
Wliebhard
    F-Series Mechanic
  • PipPipPipPip
  • 78 posts
  • Interests:Mtn. Biking, Family, Making engines fit that shouldn't.
Posted 06 July 2004 - 01:40 PM
Does anyone know where I an get the center dash section for an '85 Bronco XLT. I need the 'bezel' that holds the radio, clock, ect. and CAN NOT find one anywhere.
#2 Ktomek06
Ktomek06
    F-Series Commander
  • Moderators
  • PipPipPipPipPipPipPip
  • 509 posts
Posted 06 July 2004 - 02:42 PM
J U N K Y A R D
#3 Wliebhard
Wliebhard
    F-Series Mechanic
  • PipPipPipPip
  • 78 posts
Posted 06 July 2004 - 03:06 PM
Tried every junkyard around here, but it seems this is a common problem without a common fix. Thanks for the help though. B)
#4 Seabronc
Seabronc
    F-Series Commander
  • Moderators
  • 683 posts
Posted 06 July 2004 - 04:39 PM
What color? I may have what you need.
#5 Justshootme84
Justshootme84
    F-Series Commander
  • Moderators
  • 914 posts
Posted 06 July 2004 - 05:39 PM
Try e-bay, I have bid on several in the wood-grain pattern for my 84. If you bid high enough, you'll get one. I also have a spare, but it does not have holes for the clock, ETA and date on top. Send me a PM if you want it, Randy
#6 drcarter0734
drcarter0734
    It's Only Money, Right?
  • PipPipPip
  • 46 posts
Posted 06 July 2004 - 08:47 PM
I have found several in junk yards. I was able to order one through Ford special order, but this was 7 years ago. At that time they were a discontinued item. If you have a cracked one, you might be able to repair?? I am going to try to fabricate some aluminum or stainless dash pieces for mine. If I can get it to work and look good, I will forward some pics.
#7 BLADE262US
BLADE262US
  • Moderators
  • 281 posts
  • Interests:Ford there is nothing else =)
Posted 06 July 2004 - 11:00 PM
I think I have a complete wood grain one including the guage bezel too . Make me an offer as I have gone to the newer style dash . :D
#8 Guest_92BustinBronco_*
Posted 07 July 2004 - 10:58 AM
Search Directory for Junkyards across the U.S.A.
#9 sweepersrgr8
sweepersrgr8
    "GET ER DONE"
  • PipPipPipPipPip
  • 197 posts
Posted 07 July 2004 - 11:50 AM
broncograveyard.com.... this is JEFF's he should have one too.
1989 EB Bronco
351W HO EFI
3 Speed Auto
#10 Seabronc
Seabronc
    F-Series Commander
  • Moderators
  • 683 posts
Posted 08 July 2004 - 04:18 AM
These are the two I have with the clock, etc. cutouts. I also have the instrument bezel to go with them.
