My 78 Bronco Project
164 replies to this topic
#41 Guest_custom_78_*
Guest_custom_78_*
Posted 14 July 2004 - 01:19 PM
Another picture of the passenger side.
#42 Guest_custom_78_*
Guest_custom_78_*
Posted 14 July 2004 - 01:21 PM
freak, on Jul 14 2004, 01:17 PM, said:
Is all your tubeing mild steel?
All the tubing on the rollcage itself is 1 3/4x .120 wall mild steel. I also used 1 1/2 and 2" tubing in other areas of the same thickness.
#43 Guest_custom_78_*
Guest_custom_78_*
Posted 14 July 2004 - 01:23 PM
Here is the tube bumper I made for my Bronco.
#44 Guest_custom_78_*
Guest_custom_78_*
Posted 14 July 2004 - 01:24 PM
Here is a door panel finished without the speaker or armrest.
#45 Guest_custom_78_*
Guest_custom_78_*
Posted 14 July 2004 - 01:25 PM
Here is the picture of the front roll bar mount inside the cab.
#46 Guest_custom_78_*
Guest_custom_78_*
Posted 14 July 2004 - 01:31 PM
Here is the rear rollcage mount. All the mounts are mounting throught the body and to the frame. The cage will have a total of 12 points attacked to the frame. I think plenty strong.
#47 Guest_custom_78_*
Guest_custom_78_*
Posted 14 July 2004 - 01:46 PM
Lucnhbox, on Jul 9 2004, 07:54 PM, said:
what kind of pipe bender do you use? Your garage must be envied by most. sweet job keep new photos updated as you complete projects.
Here is a picture to clarify what bender I use.
#48 Guest_custom_78_*
Guest_custom_78_*
Posted 14 July 2004 - 01:48 PM
Bronco was pushed outside do to a jeep in the garage getting a new engine. I guess I just have to put the top on it for proptection againt all the tree leaves. Here are some picture with the top on.
#49 Guest_custom_78_*
Guest_custom_78_*
Posted 14 July 2004 - 01:49 PM
From the side
#50 Guest_custom_78_*
Guest_custom_78_*
Posted 14 July 2004 - 01:50 PM
You can see the piece of trim I'm missing from the back. If anybody has that piece please post.
Pic from the back
#51 Justshootme84
Justshootme84
    F-Series Commander
  • Moderators
  • PipPipPipPipPipPipPip
  • 914 posts
Posted 15 July 2004 - 08:30 PM
C78, thanks for the pics of the seat mounts, I'm gonna do something similar to that. Check with LMC Truck for the trim piece.
#52 Guest_custom_78_*
Guest_custom_78_*
Posted 15 July 2004 - 09:35 PM
Your welcome. And I'll check with LMC Truck. The onbly thing I need is their website or a way to contact them.
#53 4xfan78
4xfan78
  • 432 posts
Posted 16 July 2004 - 11:28 AM
C78b its www.lmctruck.com to get you're free catolog specify 78-79 bronco and you'll get it in about a week.
GOT MUD?
#54 Guest_custom_78_*
Guest_custom_78_*
Posted 16 July 2004 - 05:14 PM
Thanks 4xfan78
#55 Guest_custom_78_*
Guest_custom_78_*
Posted 22 July 2004 - 02:34 PM
More early pictures of my Bronco.
#56 Guest_custom_78_*
Guest_custom_78_*
Posted 22 July 2004 - 02:35 PM
Another
#57 Guest_custom_78_*
Guest_custom_78_*
Again
#58 Guest_custom_78_*
Guest_custom_78_*
Posted 22 July 2004 - 02:36 PM
and
#59 Guest_custom_78_*
Guest_custom_78_*
Posted 22 July 2004 - 02:37 PM
Last one
#60 Guest_BLUEovalBELIEVER_*
Posted 22 July 2004 - 09:20 PM
looks great,you are doing some really nice work like to see it when it's done
