I would like to get more Hp pluse more torque. I also do not want to really lose the mpg. I was thinking I could swap out my 302 efi with a 351 efi and I would be able to do this. I know the 351 is bigger but it would not have to turn as hard as the 302 to move the Bronco. Tell me what you all think??
Engine Swap
walkdawg
, Jul 07 2004 08:52 PM
10 replies to this topic
Posted 07 July 2004 - 09:21 PM
Believe it or not, the 302 has only about 20 HP less than the 351W. I think your year model's biggest problem with lack of power is the AOD transmission. While I am not suggesting a tranny swap, look at upgrading the AOD with a shift kit or aftermarket torque converter. And you can get up to 400HP from a 302 V8 with moderate changes like a cam and heads. I would not do an engine swap unless the mill was shot, and even then I would look at rebuilding what you have.
Posted 07 July 2004 - 10:53 PM
Any suggestions on a shift kit I was looking at a few and was not sure would work best for me. I do drive it every day to work. Its my DD for now. I am thinking of getting me a small truck to drive as a dd. but anyway. on the tranny build up could you give me some ideas what to look at? Thanks!!
Posted 15 July 2004 - 08:13 PM
Up to 400 HP, for real. not talking about nitrous or a blower, just headwork and internals. YOu can also buy a Ford crate 302 with nearly 400HP.
Posted 17 July 2004 - 06:27 AM
IF i can get up to 400 hp ut of a 302 what it the best way for me to make this happen. I can do most of the work myself. I have been working and repacing parts on cars and things for years but never really got into changing things to make it better. I would like some suggestions on what to do that would help me get good hp with more torque. Thanks for the help. I am going to be rebuilding my tranny and putting in a shift kit soon. So give me the ideas for more power.
Posted 17 July 2004 - 12:39 PM
"Stroker" kit =s a bigger-than-stock crankshaft to get a longer stroke on the pistons. Do that with aftermarkets heads and camshaft. There is alot of good info on this subject at Ford Truck Enthusiasts (www.ford-trucks.com) in their engine forums.
