Tailgate Latch
4 replies to this topic
#1 Guest_custom_78_*
Guest_custom_78_*
Posted 11 July 2004 - 06:06 PM
On my 78 Bronco the tailgate handle pulls up without even unlatchting the tailgate. I took the cover off and I can pull on the cable to unlatch the tailgate. What's wrong with my latch? I need some help to be able to fix this? Thanks.
#2 4xfan78
4xfan78
  • 432 posts
Posted 12 July 2004 - 09:15 AM
Sometimes the rods fall out of the handle or it might be that the handle is just wore out. I would see if the rods will go back in the handle.
GOT MUD?
#3 Guest_custom_78_*
Guest_custom_78_*
Posted 12 July 2004 - 09:54 AM
There is some tension when you pull on the latch and it moves the rod a little bit but to actually open the tailgate I have to reach in and pull on the rod. Everything seems hookedup? I have to change the power motor and gearbox for the rear window anyway so I'll see if anything looks wrong. Anymore info would be great. Thanks for the help 4xfan78.
#4 4xfan78
4xfan78
  • 432 posts
Posted 13 July 2004 - 08:25 AM
Might want to check the striker bolts the might be loose or need to be adjusted.
GOT MUD?
#5 Guest_custom_78_*
Guest_custom_78_*
Posted 19 July 2004 - 08:16 AM
Got it fixed. One of the brakets for the rods had bent. Thanks for all the help.
