Getting Started
#3 Guest_broncoshell_*
Posted 15 July 2004 - 05:52 PM
WELCOME TO THE ZONE!!!
Posted 15 July 2004 - 08:18 PM
FOr light duty, a Warn will work O.K., but get at least a 9K pull rating, and a roller fairlead. If you need something serious and stronger, get a MileMarker 12K hydraulic. That's what the military uses, pretty good endorsement I'd say!
Posted 19 July 2004 - 09:37 AM
Another Bronco friend killed his motor in deep water. He didn't want to start the motor in fear it will suck water up the exhaust pipe and into the motor. He winched himself out by battery (warn 8000). So make a good call on your setup.
Its a 50/50...
Posted 19 July 2004 - 10:21 AM
Dont forget to setup a gallery!
#9 Guest_Guest_Ngapuhi_*
Posted 20 July 2004 - 03:10 AM
I have an 82 XLT Bronco Ute. A rare find over here! As far as I know... the only one registered here in the north island. Was imported to this country from Australia in 1995. So...to be blunt ...I can't help about the winch but would you be able to help me?
Whats the technical name of the plastic trim around the interior of the cab ....from door pillar to the bottom of the windscreen because there was none when I bought the Bronc.
Would also like to find and purchase the dash top.... mines cracked
Any and all advise greatlly appreciated.
#10 Guest_Desert Donk_*
Posted 20 July 2004 - 05:14 AM
Ngapuhi,Kiaora ....(which means hello from New Zealand)
If you do a google search on bronco dash cap you will get 10 pages of hits. Lots of folks selling that stuff and many on ebay too. You should be able to find someone that will ship to NZ. There are two ways to buy things for your dash, one a cap that fits over what is there and the other is a complete replacement. The later being rather expensive. Either method works well enough depending on how picky you are.
A search on bronco interior trim will net a bunch of hits and you should be able to find the piece you are looking for.
#11 Guest_Guest_Ngapuhi_*
Posted 21 July 2004 - 12:39 AM
Its great to be in the zone with like minded people. And its imformative to read about other peoples problems with their vehicles and have others who have had the same experience in that area to reply with their opinion and solution.
I will try out what you have suggested in finding the parts. THANKS
#12
Posted 21 July 2004 - 07:45 PM
