i have a 88 ford bronco with 104k miles on the engine. the engine is a 351 v8 and it leaks oil out of the seals preety bad and i think it gets preety hot ofter i drive it for about 25 min. i was wondering if anyone knew how much it would cost to do all the seals over again and what i can do to keep it from getting hot.
88 Bronco Questions
Tyrell_Shoaf
, Jul 19 2004 10:03 PM
Posted 20 July 2004 - 02:55 AM
First off Welcome to the "B Zone"
My suggestion is to do a full rebuild for 2 reasons...
1) the engine has over 100K miles on it. The 351 with high mileage seems to have a problem with the bearings going bad.
2) you are already planning to tear it down anyways, why not rebuild it now.
Kits shouldn't bee too much money, less that 1000.00, and they have everything you need except the machining.
90 Bronco Full Size
Police Package
351W
E4OD
31" Tires
Police Package
351W
E4OD
31" Tires
Posted 20 July 2004 - 07:42 PM
Right, just to pull the engine to change the seals will run you close to $500. I would check the entire cooling system if you are running hot. May only be a bad thermostat, but the radiator may also be plugged up or the water pump is worn out. Any of those are things that overheat the oil and can lockup the motor really quick if you lose coolant.
