I have an 83 Bronco and I want to get a 4 inch lift for it. To complete the lift, I have the 4 inch blocks, u-bolts, and new shocks. Is there anything else i will need in order to complete the lift? Thank you for your replies.
Suspension Lift
Guest_Bronco Bill_*
, Jan 28 2004 07:42 AM
4 replies to this topic
#5 Guest_Stomper4x4_*
Posted 03 February 2004 - 10:55 PM
First off, if your rear blocks are 4 inches of lift, you'll want 6 inch coils for the front. This is how most lift kits come, as it levels out the truck as well as lifting it. COntact any lift manufacturer to confirm this if you want. I agree with everyone else on blocks though, that is not to use them unless you're mostly on the street. You can spit em out on the trail, or get that axle hop goin on and break something pretty easily. Check out Sky Manufacturing, they have a shackle flip kit for around 100 bucks, that gives you 4 inches of lift with stock springs, just a thought.
Otherwise, yeah you need the brackets, pitman arm, coils, extended raduis arms or drop brackets for those....get the extended Check a website for typical lift components.
