E4od To C6 Swap
6 replies to this topic
#1 Guest_buckinbronco_*
Posted 09 August 2004 - 03:36 PM
I have a 91 Bronco with the E4OD tranny and I want to swap to a C6. How hard is it and what exactly would I need to be able to do this besides the obvious? I know the C6 does not have overdrive and I really dont want or need it being that the main use for this truck is to screw around off-roading.
#2 sweepersrgr8
sweepersrgr8
    "GET ER DONE"
  • PipPipPipPipPip
  • 197 posts
Posted 09 August 2004 - 05:46 PM
The first things you will need are the computer from a manual, or C6 truck, and the C6 tail shaft.
1989 EB Bronco
351W HO EFI
3 Speed Auto
#3 Guest_Guest_buckinbronco_*
Posted 09 August 2004 - 05:53 PM
Do you think it would be better for me to swap or stay with what I have now?
#4 Guest_404PageNotFound_*
Posted 09 August 2004 - 06:07 PM
swap and give me your E4OD :D
E4OD's are iffy transmissions, i've blown through one, and my second one is already clunking out.
you'll have to pretty much swap in a C-6 Truck
edit: the E4OD has an Overdrive off switch if you dont want overdrive and dont want to to through the effort of going to a non OD trans :ph34r:
#5 dicain
dicain
    It's Only Money, Right?
  • PipPipPip
  • 44 posts
Posted 11 August 2004 - 07:10 PM
i did the up grades to my e4od when it was rebuilt and added a tranny cooler. it runs good now, but the first owner pulled a small horse trailer with it for the first 180,000 miles. at 190,000 the tork converter was just to tired so i had the tanny rebuilt.
#6 Guest_Guest_buckinbronco_*
Posted 14 August 2004 - 07:27 AM
Dicain, do you think i should keep the e4od or swap it out?
#7 Guest_Guest_*
Guest_Guest_*
Posted 28 December 2004 - 05:17 PM
ran across this post during a search , im looking to do the opposite , i need OD . If your still looking email me [email protected]
