I had a 4" procomp lift with extended radius arms installed a year ago. i was wondering if anyone had manufactures a leveling kit or what is required to do it. any help would be appreciated.
Level Out A 4" Procomp Lift
Guest_tagto138_*
, Aug 13 2004 04:57 AM
Posted 13 August 2004 - 08:01 AM
If its the front there are some coil spacers, but I'd just get some new coils or some that are 1" taller. Coils are cheap; the front should be slightly higher than the rear (more weight up front). Everyone seems to have a taller lift in the rear? Seems odd if you don't pull a heavy trailer. I'm only talking 1/2" taller up front max otherwise it looks funny.
If its the rear then you can add a 1" block under the leafs to keep the same ride quality. Add-a-leafs will just cause a stiff harsh ride you will not be happy with.
Wheel it like you stole it!
