Rear Slip-yoke
#1 Straight6
Straight6
    F-Series Mechanic
  • PipPipPipPip
  • 58 posts
Posted 17 August 2004 - 04:31 PM
When a slip yoke needs to be replaced do I need to replace the whole shaft or just the female section. This is an 83 bronco. Also how do I get the shaft apart?
#2 Seabronc
Seabronc
    F-Series Commander
  • Moderators
  • PipPipPipPipPipPipPip
  • 683 posts
Posted 17 August 2004 - 06:24 PM
You can get a bran new drive shaft from Jef's Bronco graveyard for 169.00.
#3 Broncoholics
Broncoholics
    Broncoholics
  • 361 posts
  • Interests:4-Wheeling!
Posted 18 August 2004 - 08:22 AM
There is a special coating you can have a driveline company put on the splines which takes up the slop. Its cheap and easy. Mine has lasted years with no problems.
Wheel it like you stole it!
