Ring And Pinion
Posted 28 August 2004 - 06:09 PM
Posted 28 August 2004 - 09:52 PM
Also your front gears should match your rear within a few tenths, or you could trash your transfer case.
351W HO EFI
3 Speed Auto
Posted 29 August 2004 - 09:24 AM
Posted 29 August 2004 - 09:44 AM
Posted 29 August 2004 - 05:55 PM
Here is an example of things you need to know, From the 83 shop manual;
Note: When changing ratios on the 44 Series front drive, it may be necessary to change the differential case along with the ing and pinion.
The front drive procedure isabout 6 pages long including Figures and charts. the tool list is a page and 1/2 a few of which could be improvised.
If you really think you want to do this, I could copy the pages and mail them to you. The one nice thing is you can do a 9 inch rear axle on the bench. Personaly, I would take it to a 4x4 shop. I say that because they sholud already have the tools.
Posted 29 August 2004 - 06:52 PM
Posted 30 August 2004 - 06:04 PM
So now that I am heading in another direction I need a little more advice. This Bronco is an 83' with an inline 300 cid carbed w/4 spd OD manual (rug trans), it has 3.00:1 ratio gears in the diffs. This is a project and will not be my daily driver but will be used on the deer lease, beach and the occasional mud hole if I can find one here in Houston and therefore needs to be street legal. Here is where I need the advice. I am going to keep this Bronco sane, and just change the tire size up to 31's and put limited-slip units of some kind in both diffs:
1) What gear ratio should I be running? (The rear diff needs to be rebuilt anyway but the front is fine so I think I can just change the ring and pinion to match whatever I put in the rear.)
2) Would I be better off buying a rear 3rd member from a place like Randy's or a used one from a place someone recommended to me?
Any and all suggestions would be helpful.
#11
Posted 31 August 2004 - 03:59 AM
Also don't forget as you go up in ratio your RPMs to maintain highway speed say 60 MPH, increases. That is offset some by your OD but still something to keep in mind.
Dynatrac use to have a reat article on their site, but I looked for it and it doesn't seem to be there anymore. I have a print copy of it. They give the following formula to pick the right gear ratio:
RPM = (336/Tire Diameter) x MPH x Gear ratio
You can also find this on pg 30 of Jeff's bronco graveyard "80 and up catalog". along with a chart calibrated at 55 so if you normally do 65 for highway cruise, you need to redo the math.
The charts don't consider you using overdrive, they are written around a 1:1 drive which is your 3rd gear ratio. I believe your OD is .7:1 but still pick gears based on the 1:1
The Dynatrac article is quite comprehensive and goes into pros and cons of the different kinds of lockers and their use. Also they cover when you should upgrade to DANA 60, etc. All I can find on their site is details about their new stuff. They don't seem to support the 44 any more on the site.
http://www.dynatrac.com
#13
Posted 02 September 2004 - 08:45 PM
