35's On Stock Bronco
#21
Guest_Windchaser_*
Posted 23 September 2004 - 09:28 AM
#22
Posted 23 September 2004 - 12:15 PM
#23
Posted 23 September 2004 - 02:49 PM
From there, you have to telll the program where to put them, I think the default is MY Pictures. I then use a photo processing program to resize them (I keep it at a size that easily fits the forum and of a quality that keeps it under 100K. From there, I post to the forum, link below.
If I'm going to put them I keep them still under 100K but size them a little larger. I believe the Zone resizes them to the size they want when you upload them anyway.
So if you don't know how to process pictures, I'd get someone to help you thru it the first time. Once you have done it, it's easier than it sounds.''
Like this picture of my heat blanket
#24
Guest_Windchaser_*
Posted 24 September 2004 - 07:09 AM
#25
Posted 26 September 2004 - 02:59 PM
No personal experience here, but from everyting I've read on the 460 in Bronco is that, if you haven't snapped an axle or cleaned out your differential YET, and you do any serious off roading, it's just a matter of time. Dynatrac says that the 9" can be beefed up with aftermarket parts to almost as strong as the Dana60 but the cost is substantial. Also they say that most 3rd members for the 9' are made of regular cast iron and not as strong as other 3rd members. They say the best application for the 9" is in a vehicle 1/2 ton or less.
Based on what Dynatrac says, I'd go find a 60 or 70 if I were to change mine.
#26
Posted 27 September 2004 - 02:09 PM
http://www.supermoto...ail.php?id=6261
im gonna take more because the best ones came out dark
Turner
#28
Posted 29 September 2004 - 01:55 PM
#29
Posted 30 September 2004 - 07:22 AM
