after i got done crying i figured i'd try and replace the transmission. My old one just went out.. it'll go into first, reverse, park, and neutral but will not shift into 2nd, 3rd, or 4th. it's an automatic w/ overdrive. ONLY problem is.. I don't know whether it is a C-6, E4OD, or AOD. I have an 88' Bronco FS w/ automatic transmission. I don't have the original book that came with the truck. I don't think that it is a C-6 but I don't know which of the other two it is.. anyway to tell without the owners manual? I have an alt. tranny which is an E4OD out of a 93' fs bronco.. but i rolled it and it burnt the housing up on it but the internals are still good. I just need to know if my tranny out of the 88 is a E4OD so i can put my internals into it's housing. Thanks any help is GREATLY appreciated.
Tranny
Guest_GTFord_*
, Sep 16 2004 10:39 AM
11 replies to this topic
#2 Guest_GTFord_*
Posted 16 September 2004 - 10:40 AM
ahh and btw i believe the reason it won't shift is because of the "rear drum" the one that controls gears after 1st. At first i thought it may be some sort of valve stuck so i added Trans-X and it still did nothing for it.. well figured i'd throw that in
#4 Guest_BigNasty_*
Posted 16 September 2004 - 05:41 PM
I don't think it will be a C6 as I have never heard of anything other than a 3 speed C6
As for the other trannys.. I have no idea if any or all of the parts would interchange or not.
Best bet may be to just have a shop rebuild the one you have.
Posted 17 September 2004 - 06:43 AM
What motor do you have in it and what transfer case does it have?
90 Bronco Full Size
Police Package
351W
E4OD
31" Tires
Police Package
351W
E4OD
31" Tires
Posted 17 September 2004 - 08:05 PM
GTFord, you can look at the tranny code on the door jamb, or crawl underneath the Bronco and look at the shape of the pan. The E4OD has a notch in one corner, like the C-6 does. The AOD is somewhat square, no notches. It is likely that you have the AOD in a 87-89 Bronco.
CBD, the C-6 is a tougher automatic ttranny, but does not have overdrive (OD). The later-model E4OD after 1992 is a better tranny than the AOD or the earlier-model E4OD ones.
#11
Posted 18 September 2004 - 07:32 PM
GTF, if you are going to get the E4OD rebuilt, see if you can upgrade to the newer-model parts. I know a few folks that have had to pay about $2500 for the job, so you might as well get the best out of it.
#12 Guest_Big Baldo_*
Posted 18 September 2004 - 08:26 PM
Hi Guy I got a 1990 bronco that I went through the tranny stuff the new trans are better for sure but your 88 has the aod I had my e40d rebuilt by art carr raceing trans it ran me about 4,000 three years ago it was the best thing I ever did it now shifts like a trans should no more shifting out of passing gear just as power starts to build I also rebuilt my engine at the same time and art carr set the shift pattern to the cam specs lets just say it was money well spent ..the truck does the 1/4 mi in 16.03 not to bad for a daily driver.........
