6.7miles Per Gallon
12 replies to this topic
#1 BADBLOODRUSH
BADBLOODRUSH
    Duck Tape L'fixer :)
  • PipPip
  • 24 posts
Posted 08 October 2004 - 11:30 PM
i just got a 1980 bronco it has a 302 in it . its got some 38 buckshot on. it getting 6.7miles per gallon how can i get better gas mileage?? plz help
what kind of mileage are you all getting????
#2 BADBLOODRUSH
BADBLOODRUSH
  • PipPip
  • 24 posts
Posted 08 October 2004 - 11:45 PM
thats 129 mile to a full tank 19gallon tank i hopeing to get 10mpg 190 to a tank or am i dreaming?
#3 Justshootme84
Justshootme84
    F-Series Commander
  • Moderators
  • PipPipPipPipPipPipPip
  • 914 posts
Posted 09 October 2004 - 12:49 AM
I thought your tank is 32 gallons??? That's even worse, about 4 mpg. Assuming the engine is properly tuned, no vacuum leaks, and the carb is good, you should get around 8-10. The 38's are definitely straining your powertrain, too. You should be running 4.88 or even 5.12 gears, so a gear swap may be the answer. I would work on the motor first, as a tune-up is a whole lot cheaper!
I now get 11.5 mpg with stock 3.50 gears and 35" tires. I was getting 6-7 mpg with the POS factory carb and intake.
#4 Guest_Streetgang44_*
Posted 09 October 2004 - 03:46 AM
With a fresh tune up, and EVERYTHING else possible in order, including a set of gears that can get you away from a stop light with those 38's at normal RPM.......you mileage should be at about 10MPG.....at best.
#5 BK85
BK85
  • PipPip
  • 14 posts
  • Interests:85 XL Full Size, 302FI, 4spd manual, Alloys, 31.5" BFG Long Trails, Westin Step Bars, Front Seats and Console out of an Eddy Bauer, Sounds from a Taurus. 180,000 miles without a rebuild and still kickin.
Posted 11 October 2004 - 01:18 PM
Geez! I thought my 11 MPG was bad. I've got an 85 302 FI with manual trans. running 31x10.5x15 tires, stock rear end and way overdue for rebuild. Oh the 80/86s do have a 32gal gas tank stock.
Bill
#6 bluesman17
bluesman17
    F-Series Maniac
  • PipPipPipPipPip
  • 164 posts
Posted 11 October 2004 - 04:36 PM
Im at 14 mpg just as long as my leg doesnt get bored.
#7 hawk2100n
hawk2100n
    F-Series Maniac
  • PipPipPipPipPip
  • 153 posts
Posted 11 October 2004 - 05:27 PM
my 351 gets about 11 on the highway. just tuned it up so mabey it will be a little better. I just wish i could get a ford version of the new LS2 in the corvette. 400 hp and 27 mpg on the highway.
#8 BADBLOODRUSH
BADBLOODRUSH
  • PipPip
  • 24 posts
Posted 12 October 2004 - 04:15 AM
should i just get a new motor will it help should ?
#9 Justshootme84
Justshootme84
    F-Series Commander
  • Moderators
  • 914 posts
Posted 12 October 2004 - 03:10 PM
Even a stock, new motor may only get 11-13 mpg average in the Bronco. My advice is to fix whatever problems your present motor has with a possible gear swap, if you plan on keeping it for years to come.
#10 drcarter0734
drcarter0734
    It's Only Money, Right?
  • PipPipPip
  • 46 posts
Posted 13 October 2004 - 10:06 PM
I am lucky to get 8 mpg in mine. The carb has been rejetted to get that from 5mpg. Price of a BBF. Unfortunately these trucks werent made with economy in mind. My 80 with a 351M and 4 spd only got 11 even after having it rebuilt, balanced and blueprinted.
#11 Guest_click tracy_*
Guest_click tracy_*
Posted 14 October 2004 - 04:58 PM
I get 17mpg in my 83, 31" tyres, 250ci straight 6 crossflow, 3.5 diffs. Did they build sixes in them over there? Nearly all v8 f-series pre efi(and probably some with efi) run on LPG over here due to their thirsty nature.
#12 Guest_streetgang_*
Guest_streetgang_*
Posted 14 October 2004 - 05:46 PM
Yes.....they were made with a available 6 cyl. I just aint too sure about the year range.
So.....where are you from.....your telling me that gasoline is that expensive that if you want to drive a real "FULL SIZE" SUV that you have to use LPG?
I get about 12 MPG here in New York City.....but thats only if I aint in a hurry. On the highway I can get as much as 18 MPG.....but it takes a lot of will power not to go too fast.
#13 Guest_click tracy_*
Guest_click tracy_*
Posted 18 October 2004 - 03:48 PM
I'm in Eastern Australia and fuel is $1.10/litre which is about $5/gallon and yes most V8's and big sixes run LPG at about 50 or 60 cents/litre.
