i have a 79 bronco with a dana 44 front. i also have a 78 f250. ihave put the rear dana 60 from the f250 in my bronco and would like to swap the front. i would also like to keep the coil suspension. i heard that i can swap the steering knuckles out to get the bigger bearings, brakes, and eight lugs. i was wondering if the dana 44 from the bronco and the dana 44hd are the same from the knuckles in. any info would be great. thanks.
3/4 Ton Conversion
Guest_brianmelnikow_*
, Nov 18 2004 09:45 PM
Posted 06 January 2005 - 06:56 PM
The rear D60 should bolt right in with no fuss.Here is a related post i made.
http://broncozone.co...?showtopic=2376
