Transmission Swap
Guest_Kevin_*
, Jan 07 2004 03:47 PM
10 replies to this topic
Posted 08 January 2004 - 09:26 AM
Any transmission that was behind a 300, 302, 351C and 351W will fit your engine. That gives you a choice of a c4, a c6 (stronger than the 4) AOD, and an E4OD
Posted 15 January 2004 - 08:16 PM
Umm, he's asking about automatics
Posted 15 January 2004 - 08:45 PM
That's what I'm sayin... slap in a C6
But I doubt any of this matters, since it's unlikely the person will be back
#9 Guest_Stomper4x4_*
Posted 03 February 2004 - 11:06 PM
Probably true. But we might give such insightful advise he may actually register. My sage wisdom for today is (drumroll................................) C-6!!!That's what I'm sayin... slap in a C6
#11 Guest_ron753_*
Posted 09 May 2004 - 07:37 PM
a c-4 would be a good trans for that engine lighter weight and still strong
enough you should make sure it is a 4X4 trans and it would be a good idea to install an integrity cooler the cost is low and they will keep the trans. cooler
for longer life and better performance
