I have a 93 that has bad body craks at the end of the rain gutter where the top meets, from what ive seen this is very common. anyone have and good fix's?
Body Cracking
Guest_blue&white bronco_*
, Feb 23 2004 10:13 PM
#2 Guest_Gunner_*
Posted 24 February 2004 - 09:06 AM
Depends on the size of the crack. if the crack is gapped at larger than 1/4 inch then i would say to cut out the bad spot and wled in a new piece of sheet metal. if it is just a small crack just get yourself some sand paper and fiber glass. sand the area surrounding the crack and fiber glass it up then sand it smooth and repaint to match. its actually quite easy. alot of people get scared to used fiber glass. just read the instructions and get the mixture of resin and hardener correct and you will be good to go. even if you mess it up you can just sand it back off and try again. or if you live in the MA area let me know and i will hook it up for you. hope it helped. oh and you can find fiberglass at any auto shop or like home depot and lowes.
Posted 17 March 2004 - 08:59 PM
If you are good with "bondo" maybe you would be willing to try lead. All you need to do is melt it down & keep it heated with a propane torch so that it works like wet bondo. There is more to it than that (cleaning out the old filler putty, sanding etc.) but with some practice on scrap metal you should have no trouble doing it.
90 Bronco Full Size
Police Package
351W
E4OD
31" Tires
Police Package
351W
E4OD
31" Tires
