need help
Posted 24 February 2006 - 05:42 PM
400 engine, np435 trans,
np205 transfer, 10 " lift
4.10 gears, color black
no pics as of yet, hopfully
soon
Posted 04 March 2006 - 04:58 PM
catalina- you will need to check your bolt pattern also and more than likely get a new clutch and flywheel.. If bolt pattern is wrong you can change your bellhousing by removeing the 4 bolts from inside the bellhouseing where it attaches to the trans. hope it helps
soon
Posted 29 March 2006 - 03:08 PM
rip- you will need to get a flywheel to match your engine. wiring should not be a problem sense you are not messing with the trans. You may want to check the bolt pattern on your tans. to see if it matches your new engine you can do that by useing the plate betweenthe trans. and engine. Hope that helps.
if i was to change my engine 390 to 302 and use the same tranny c6 if ican,would i just have to change the bellhousing on it and use the same tourqe converter iknow i would need a flex plate for the 302
Posted 29 March 2006 - 07:34 PM
the 390 and 302 are different bolt patterns. also the c6 doesn't have a removable bellhousing. you would need a small block c6 which would fit a 302. the 390 is a big block bolt pattern
Posted 05 April 2006 - 05:54 AM
