I have a 79' Bronco that my daughter got into an accident with where I have had to replace the front clip to fix the damage. There is a vacuum canister that sits under the driver side metal inner fenderwell and to the front of the plastic inner fender lining that I removed a hose from but can not now find the hose or where it might have served. I have the vacuum canister that sits in the engine bay on the driver side fenderwell and all the hoses and connections are accounted for. What does this other cansiter serve??
Vacuum Canister?
Guest_tkocurek_*
, Feb 24 2004 02:20 PM
4 replies to this topic
Posted 29 February 2004 - 07:15 PM
I can't believe noone has helped you yet,the lines all depend on the truck,air,all kinds of crap.I would go and check out other trucks and bronco's or go to a library and check the books they usually have them in the referance section and they date back too the beginning of time.
#5 Guest_rlynch131_*
Posted 01 April 2004 - 05:19 PM
Here is a link to a guide for routing and connecting your vacuum hoses. I believe the vacuum canister is more of a resivoiur for your heater controls and vent baffels.
hope this helps
http://www.projectbr...lyst_vacuum.htm
hope this helps
