I need some help with a strange electrical problem. When my parking lights and headlights are off, the turn signals on my 77 F-150 work fine. However, when I turn the parking lights and headlights on, the turn signals do not blink, they remain steady, but the turn signal indicators on the dash blink indicating the flashers are working fine. I'm not sure what happens when the parking lights are turned on that would impact the signal circuit.
Any thouhts?
Page 1 of 1
Turn signal problem
Posted 21 May 2006 - 09:48 AM
Any thouhts?
Any thouhts?
Think, a guess, that a bulb base is corroded; flasher is weak;
had same w/our ex 78 Bronco Ranger; a bulb base was corroded; we drilled, tapped and placed a new GRND for a common GRN connection at the frame for every bulb, esp the license plate bulb ; if you look at the diagram and visualize removing a ground for a turn sig bulb socket...............
for a general test, Look here:
http://aarc.epnet.co...n/8576/8576.htm
CHASSIS ELECTRICAL
WIRING DIAGRAMS
use #1 dia for the year.
to ck signal turn switch connector at strg col base
ign sw ON
eng not running
use a 12 v test lt or mm and ch for power @ light Blue wire; conn, other test lt lead to a good ground; test light should glow
w/ turn sig lever on right or left, probe the connector for power out of the turn sig switch in each of following wire locations;
left front lt grn wire w/white stripe
left rear - lt grn w/orange stripe
right front - white w/light blue
right rear - orange w/light blue
test light should flash at each location
turn turn sig lever to right
or, I need more time to look at diagrams; have to go now...will try mon or Tues. these are Chilton pics and they don't match what I see in the printed version, as usual
Check out our Ford Bronco, Trucks & Vans Web site
Thanks to All Who Serve
Posted 26 May 2006 - 08:55 AM
Any thouhts?
Any thouhts?
I had the same problem with my 77 Ford truck. The thing I found was that one of my tail-light sockets was corroded. What I did was order a new tail-light socket from the Bronco Graveyard. A simple installation. Just snip the old socket off and splice in the new one. The socket came with pre-installed crimp on type connectors. Ordered it through email and had it within that same week. Good luck with your truck.
Posted 05 April 2008 - 06:09 PM
not sure if this is still active or if you fixed the problem. but is it just the front that remain steady? or the rear as well? if its just the front check the turn signal sockets. there should be 3 wires coming out. a ground, hot, and one other one. not sure what its for. but when i replaced the front flasher sockets in my 77 f-150 i incorrectly wired them and the third wire cause the flashers to stay steady with the head lights on. so take a test light and test each wire to see which one goes on with the headlights and simply disconnect this wire from the socket. ive never had any problems with mine and the flashers work fine with or without headlights on.
Page 1 of 1
Sign In
Register
Help
Add Reply
MultiQuote
