Axle Swap
#1 Guest_roy_*
Guest_roy_*
Posted 24 February 2004 - 08:34 PM
i have a 76 crew cab with a 16 spline dana 60. would like to know if i can change to a 30 spline with out having to change axle housing or if all i have to do is change outter baerings. plan to put air or electerc locker in. help much needed [email protected]
#2 Txquadhunter
Txquadhunter
    F-Series Maniac
  • Moderators
  • PipPipPipPipPip
  • 241 posts
Posted 25 February 2004 - 12:03 PM
To get away with it cheaper your best bet would be to drop the D60 rear and swap in a sterling from a mid 80's to early 90's F250 or F350. it'll swap right in. plus lots of aftermarket parts found for them. they are a much stronger rearend then the D60. you should be able to pick up a sterlin rear and locker cheaper then you can convert your 60's spline count. IMO
