Ford F Series Zone - F150 F250 F350 Super Duty Ranger Tech: distributer drop in - Ford F Series Zone - F150 F250 F350 Super Duty Ranger Tech
Page 1 of 1
distributer drop in i need to know
#1 User is offline   79 ford
  • F-Series Newbie
  • Group: Members
Post icon  Posted 09 September 2006 - 06:07 PM
if anyone would be so kind as to tell me how to drop a distributer in a engine that dosent have one in it at all is it is a 74 390 if you could please give me detailed instruction it would be mutch appreciated thanks!
0
#2 User is offline   corn fed
  • Where's My Hammer!?!
  • Group: Members
Posted 31 March 2008 - 05:15 PM
Using a chilton guide or similar, find #1 cylender. Manually rotate engine so #1 in TDC. Drop the distributor in place so the rotor lines up with the plug wire on the dist. cap for #1. When you crank the engine, #1 should be the first plug to fire. As long as the plug wires are in the right places on the cap you should be good. If you get nothing out of the engine, pull the dist. out and manually rotate the engine untill #1 comes to TDC again. Repete your steps. It is hard to tell if you are on a compression/power stroke or exhaust/intake stroke.
0
Page 1 of 1
Fast Reply
