does a 1983 ford ranger with dura spark ignition have a resistor between the ignition key and the ignition module . if so is it a resistor or a resistance wire. i have no voltage reading in the red wire on the module and no spark to the plugs . can i use a test lead and put 12 volts to the red wire without harming the module to see if i can get spark to the plugs. my ford ranger repair manual haynes 36070 shows a resistor in the circuit but trouble shooting procedures indicate the module red wire should have a voltage reading equal to the battery voltage reading. what fuse in the fuse box woulds protect the circuit from the key to the module
Dura Spark
Guest_RoadWarriorRepair_*
, Feb 26 2004 07:25 AM
