1990 Style And 1995 Style Interchange
5 replies to this topic
#1 Guest_amcabbott_*
Guest_amcabbott_*
Posted 26 February 2004 - 05:24 PM
I have a wrecked 1995 that needs a front clip (no frame damage) everything from the rad suport fenders inner fenders grill bumper filler ect. I have a mint condition front end on a 1990 with a bad rear frame and 1/4s to use for parts. other then the bumper mount will it work. has anyone done this please email me. [email protected]
#2 Guest_azrockrat_*
Guest_azrockrat_*
Posted 26 February 2004 - 08:04 PM
i have seen 92 and up front clips put on 87-91 body's. but it should work the other way. it is not a direct bolt on you have to redrill holes on some of the stuff
#3 Guest_Raven_*
Guest_Raven_*
Posted 26 February 2004 - 10:48 PM
yea it should minor differances here and there ..
#4 Txquadhunter
Txquadhunter
    F-Series Maniac
  • Moderators
  • PipPipPipPipPip
  • 241 posts
Posted 27 February 2004 - 01:05 PM
The complete front clip is a bolt on, no extra holes to drill. just be sure you pull the core support asnd clip in one piece. not easy to piece them together on as diffirent model truck. plus less bolts to pull. took 2 of us about 3hours to swap a 95 clip onto a 87. on your 95 you'll find it has a extra bolt on the bottom of the fender that the 90 won't have. but no need trying to fad a fender bracket for it as it ain't needed. just mounting bumper brackets where you may have some fabing to do. (I know you do to mount the 92-96 style bumper on 80-86) since the 87 e did the 95 swap had a wench mount we didn't mess with adding the bumper. so just look at the brackets to see what you'll need to do. as for the suport/clip a easy bolt on. you'll also need the hood and cowl from doner
#5 Guest_amcabbott_*
Guest_amcabbott_*
Posted 28 February 2004 - 04:36 PM
thanks for the help i may just do it. how ever i realy like the 92-96 style front mine is an xlt I'm still up in the air. a mint shape xlt clip is $1200.00 to $1800.00 in my area.
#6 Shadow_D
Shadow_D
  • Moderators
  • 271 posts
  • Favorite F-Series Year?:1999
Posted 16 March 2004 - 07:20 PM
What are you going to do with the rest od the 90?
90 Bronco Full Size
Police Package
351W
E4OD
31" Tires
