ok, I am new to the site and had a few questions. I have a 2001 supercrew 4x4 with a 5.4 in it. I was wondering about the 3" body lift on these trucks. I do tow with the truck and the truck see's ALOT of off road. I do not have the money for the suspension lift and am wanting to fit larger tires. Will the body lift last or is it going to be something that I will regret? Any help or suggestions would be greatly apprciated.
Body lift
cowboy6365
, Mar 05 2007 02:05 PM
Posted 04 August 2009 - 08:33 PM
If your doing some major off roading I wouldn't use a body lift, but I see that your only using a 3in, so it would probaly be alright, as long as its done right.
1996 F-150 XLT 4x4 351 V8, E4OD, RV Cam, 4" lift, KC Rollbar, Cow Bumper w/6,000lb. winch, 4:10 Gears, 33"x12.50-15 Swampers. Warn lock-outs, D44 IFS Front, 8.8" Built Rear end.
Daily Driver- 1996 F-250 XLT 4x4 460 V8, E4OD, 6" lift, Brush Guard , Dana 60 Front Conversion, 10:25 Full Floater Sterling Rear end, 4:10 Gears, Splicer Lock-outs.
1996 F-350 XLT 4x4 Crew Cab, 7.3L Power Stroke Turbo Diesel. E4OD, Frame-off Resto. Chipped, Banks Exhaus t w/dual Stacks, Jake Brake,
4:10 Gears, 235,250 miles.
1989 Ford Mustang GT, 5.0L, 5-speed, 4:10 gears, Holley Carb, offenhauser intake, Project in progress....
Posted 05 April 2013 - 10:22 PM
I'm not much of one to lift trucks, but I don't completely agree with body lifts. Makes the truck more top heavy with the same suspension set-up, just a lil' fact that makes me not like body lifts. Since its only 3"(s) One ton Avenger is right, If done correctly you'll be fine.
Edited by Skitter302, 05 April 2013 - 10:24 PM.
