4wd truck and 2wd tranny
#1 rusty81
rusty81
  • 5 posts
Posted 07 April 2007 - 05:55 PM
i have an 81 150 4wd with a 300 and a c6. i was lookin at doing a manual swap. i found a donor truck, but it is a 2wd. i was wondering what all needs done to put this tranny in my truck, and keep the 4wd. can my np-208 bolt up to this tranny? what adapters are nescessary. the donor truck is an 83 250 2wd with a 300. thanks
#2 rusty81
rusty81
  • 5 posts
Posted 12 April 2007 - 06:01 PM
i guess no one has any helpfull advice :( i think that all i have to do is swith the tail shaft assemblies on the manual to mate it to the transfer case. if you know any different,please le me know. thankz
#3 andre 244
andre 244
    Duck Tape L'fixer :)
  • PipPip
  • 23 posts
Posted 22 September 2007 - 07:43 PM
yes ive done it 1989 f 150 4x4 manual tranm 8 cyl
in to a 1991 f150 2wd auto 1991 now 4x4 v8 manual
wirering for the box ad to b change because 4x4 shitf swicht for the ligth in dash.
also ad to change steering because 1991 ad cruise control
the dash board to but verry easy to do
BUT FOR TRANNY I THING U NEED MANUAL TRANM AND TRANFER CASE 4 MANUAL
GOOD LUCK
Edited by andre 244, 22 September 2007 - 07:48 PM.
#4 Bear76
Bear76
  • PipPip
  • 22 posts
Posted 01 February 2008 - 10:01 AM
All you do need is to change the tailshafts with the right intermediate housing. BroncoGraveyard sells these used, you just have to make sure you know the correct length you need. After that it is a bolt on operation (I hate when I say that, because it is rarely ever that way.)
I have set up my 2wd with a transfer case doing it that way and it worked decent. If you had a 4wd drivetrain available, it is better because then you know everything will bolt together.
Good Luck.
Build it.
Beat on it.
Break it.
Build it better.
