I have a 78 f150 4x4 when i get up to 30 mph I get a vibration I thought it was in the transfercase so i swaped in a 205 for the 203 transfercase. didnt fix so i replaced the radius arm, and track arm bushings didnt fix any ideas on what my next step would be.
Page 1 of 1
bad vibes
Posted 21 June 2007 - 10:14 PM
[quote name='phatkat' post='18682' date='Jun 2 2007, 06:43 PM']I have a 78 f150 4x4 when i get up to 30 mph I get a vibration I thought it was in the transfercase so i swaped in a 205 for the 203 transfercase. didnt fix so i replaced the radius arm, and track arm bushings didnt fix any ideas on what my next step would be
This post has been edited by usmc triggerman: 21 June 2007 - 10:17 PM
Posted 02 July 2007 - 07:00 PM
Hey dude, don't just throw parts at it...... check the easy stuff first. It could be a tire starting to separate or a broken motor or tranny mount. Is the vibration coming from the drivetrain or the wheels.... borrow a set of tires from a friend and swap out or rotate to see if the vibration moves or goes away. Does the transfer case shifter move around alot during excelleration? Little things can make alot of noise/ vibration.
Posted 09 August 2007 - 09:10 AM
jack up the front end and shake the tires, if the trie wiggles then it's your wheel bearing. if the tire wiggles and the knuckle wiggles with it then its you ball joints. if you have tires bigger then 35's theres nothing you cand do. its called the death shakes
Page 1 of 1
Sign In
Register
Help
Add Reply
MultiQuote
