I have a 1989 F450 460 engine that stumbles/hesitates at low rpm or idle, then runs fine after that. Put in new spark plugs, fuel filter and air filter, but still happens. Any suggestions? Thanks, Mike
Engine Stumbles at Idle F450 1989
ironworker
, Jun 03 2007 07:11 PM
Posted 15 June 2007 - 08:32 AM
Hey, Here's my experience with these engines. First, check for a vacuum leak at intake. I use a propane bottle with nozzle to test. Have used carb clean but it's possible to get flash if ignition is faulty. Also, second possibility could be a faulty TPS. These sensors can fault anywhere in the resistance coil. If you sit and idle for long periods, it can wear at that point. Hope this helps. 50F1wrench.I have a 1989 F450 460 engine that stumbles/hesitates at low rpm or idle, then runs fine after that. Put in new spark plugs, fuel filter and air filter, but still happens. Any suggestions? Thanks, Mike
