I have a 73 F-250 with a 360 engine and c-6 transmission with divorced transfer case.I am swapping out the 360 for a 460.
My problem is the trans,they have different bell housing bolt patterns.What trans should be used? Any help is greatly appreciated.
1973 F-250 460 swap from 360
Hammer
, Apr 21 2008 02:52 PM
4 replies to this topic
Posted 23 April 2008 - 06:13 PM
find one out of a 77 to 79 never ran into that problem before.I have a 73 F-250 with a 360 engine and c-6 transmission with divorced transfer case.I am swapping out the 360 for a 460.
Posted 27 April 2008 - 07:36 AM
yeah it's called the FE bellhousing,you need a bb trans,351m/400/429/460.the c-6 will be all one unit and big,the FMX is 2pc and is half aluminum and cast.good trans but not much after market parts,c-4 is another 2 pc,they didn't make very many bb c4's.
I'd look into a overdrive trans,you get a lower first gear and the odrive.you can get kits to run them on non computer controlled trucks.
Posted 28 April 2008 - 04:33 PM
when the t-case is divoreced they just use a 2wd trans.so why not use a odrive 2wd trans?any car,truck,van,bus that had a 351m,400,429,460 and was 2wd.the trans will work.c-6 that is.any will work you will just have to lentghen or shorten the drive shaft to the t-case.
