Ford F Series Zone - F150 F250 F350 Super Duty Ranger Tech: AOD transplant - Ford F Series Zone - F150 F250 F350 Super Duty Ranger Tech
Page 1 of 1
AOD transplant transmission change
#1 User is offline   daler63
  • Duck Tape L'fixer :)
  • PipPip
  • Group: Members
Posted 01 June 2008 - 09:52 PM
My C6 is showing signs of impending failure and Im thinking of trying for better gas mileage.Im sure its possible to put in an AOD transmission but first,which one would be best and would I need to change columns or would it be better to install a floor shifter?Any advice is appreciated.
Dale
78 F100 2WD 351 windsor C6
This post has been edited by daler63: 01 June 2008 - 09:54 PM
0
#2 User is offline   jackndelphine
  • PipPip
  • Group: Members
Posted 05 June 2008 - 05:19 PM
You could check out a tranny from a late 80s lincoln, or mustang, I have an AOD out of an 89 LSC and I know that tranny is not shifted by the computer. It works off the detent cable, which is absolutly detrimental to have adjusted properly or else you can fry the tranny in a heartbeat. Anyway that tranny should work with any SB Ford. I would go with a floor shifter due to having to deal with fabricating linkage to adapt to the column shift, floor shifter would be easier. Anyway, I hope that helps--------Jack
0
Page 1 of 1
Fast Reply
