I have a 1977 F-150. It had a 351M. with a C6. Now Im putting in a 460. I want to use the same transmission. What all needs changed for the trans to work?
Page 1 of 1
460 swap
Posted 25 December 2008 - 08:05 PM
the 351/M/400 is a big block as is the 460 the trans is the same the only thing i can think you might have to change is the trans kick down but it should work Did the 351/M have a 2 bbl carb The 460 will be a 4 bbl set up so like i said the trans kick down might need to be changed you will most likely need to adj the throtle linkage as it will be longer for the 351/M due to the 2 bbl carb
Page 1 of 1
Sign In
Register
Help
Add Reply
MultiQuote
