No fire after water pump change 79 400m elec ignition
4 replies to this topic
#1 Jjona5
Jjona5
  • 2 posts
Posted 31 January 2009 - 11:27 AM
I changed the water pump and thermostat in my truck(didnt have a thermostat when I bought it and the water pump started leaking). Now I put it all back together and im getting no fire at all. The coil is hooked up and getting voltage. The electronic module has been replaced(since the problem) and I'm not sure how to test the trigger in the distributor. Any suggestions?
#2 Jjona5
Jjona5
  • 2 posts
Posted 31 January 2009 - 12:59 PM
I figured it out...there was a shorted wire...
#3 Justshootme84
Justshootme84
    F-Series Commander
  • Moderators
  • PipPipPipPipPipPipPip
  • 914 posts
Posted 31 January 2009 - 01:01 PM
You may find some help on the AutoZone website. Did you remove the distributor to change the thermostat?
#4 Justshootme84
Justshootme84
    F-Series Commander
  • Moderators
  • 914 posts
Posted 31 January 2009 - 01:02 PM
OK, I see you figured it out. Are you from Houston?
#5 BlackFord77
BlackFord77
    BlackFordTruck
  • PipPipPipPip
  • 67 posts
Posted 21 February 2009 - 06:01 PM
I hate wire shorts. They're a pain to find some times.
