Edited by Redneck390, 11 February 2009 - 11:22 PM.
360 and 390
Posted 11 February 2009 - 11:21 PM
390FE Big Block, 4-Speed, NP205
Dana 60 FF Rear
Dana 44 Closed Knuckle Front
Posted 11 February 2009 - 11:40 PM
So i was wondering how you tell a 360 from a 390? Im pretty sure there the same engine down to the cranks and rods bein diffrent, may be wrong but i know that they look alike. I was wondering if theres a way to tell by just lookin at it, cause if it turns out my truck has a 360 id consider trackin down a 390 or swapin in 429.
have a machine shop run the block numbers they will know and a 429 does not interchange with that family group would have to make some transmission changes to do so
Posted 12 February 2009 - 03:49 PM
On the 390, look at the intake and the heads, if you have to take the valve covers off it is a 390. meaning that a little bit of the head is the intake
yes you can change the bell housing out on the t18 and t19 four speed the bell housing from the 351m and the 400 will fit the 429 460 engine family count your valve cover bolts another guy listed these nice to keep in mind
8- 351C/351M/400
7- 429/460
6-289/302/351W
5- 352/360/390/428
Edited by freeto4wheel, 12 February 2009 - 03:56 PM.
Posted 21 February 2009 - 03:34 PM
Dana 60 FF Rear
Posted 03 March 2009 - 12:08 PM
the 360 had fair torque ratings and had heavy duty internal components for truck use even though the 390 had better horsepower for performance, it just depends on youre wheelin environment or what you want to do. i dont think that you can go wrong with either one.
Posted 15 May 2009 - 06:36 AM
he only difference between the 360 and the 390 that i know of is the crank and the rods. The 360 has a short throw with the crank compared to the 390 and it makes the piston travel up with long rods. The 390 has short fat rods. I have seen alot of the 360's come apart because they break a rod.So i was wondering how you tell a 360 from a 390? Im pretty sure there the same engine down to the cranks and rods bein diffrent, may be wrong but i know that they look alike. I was wondering if theres a way to tell by just lookin at it, cause if it turns out my truck has a 360 id consider trackin down a 390 or swapin in 429.
#11
Posted 25 June 2009 - 05:48 PM
hey bud, i had a 390 in a 79 bronco that i put in myself. i had the same issue and i discovered that if you take the trans off, take the flywheel off there will be a casting # that will tell you what you have. the 352 stamp on the front right side under the head is typical on all of these blocks. if you find that # on the back of the block it will allow you to find out. good luck! great motor! i liked mine.he only difference between the 360 and the 390 that i know of is the crank and the rods. The 360 has a short throw with the crank compared to the 390 and it makes the piston travel up with long rods. The 390 has short fat rods. I have seen alot of the 360's come apart because they break a rod.
