Edited by 1995 f-250 4X4, 26 February 2009 - 01:35 PM.
1995 f-250 ext cab 4X4
1995 f-250 4X4
, Feb 26 2009 01:03 PM
5 replies to this topic
Posted 04 March 2009 - 11:13 AM
Check your body mounts. See if they're the same size. Look for any objects the bed might be sitting on.. Ie wrong size gas tank.. Are the bolts tightened down? Do any of the mounts look pressed in or pulled up? Some folks like to tie stuff in the bed up using the sheet metal of the bed. Maybe it got torked up? Look at your box lines, you might be able to use a level, and see if the box is warped.
