Can I fit 31 X 10.50 tires on a stock '79 F-150 4x4?
How large can you go without clearance issues?
4x4 tire size
walkercreekbronco
, Apr 11 2009 04:40 AM
5 replies to this topic
Posted 06 May 2009 - 06:58 AM
On 79 and older f-150s your can run a 33x12.50 on it at stock height.THe trouble is when you turn sharp teh tire will hit the radius arm and rub.With a 2in body you can run 35x12.50 no problem other than it hitting the radus .but you have plenty of cleance is you sink to the tire up in the wheel well while 4 wheeling.I stepped my 77 up to 6inches of lift and had 38x15.50 super swampers on it.It was close in the front but it cleared ok.My on problem was it rubbed the raduis arms on sharp turns and the ps front tire would rub the hear on that side.I have the l&l headers that come out ove the frame rails.But I stepped back down to a 35.in tir once I wore out the 38s.Didnt need that big a tire.
1985 Bronco 427 small block
C-6 with a 208 transfer
33x12.50-15 all terrain tires
Stock 5.8 with E40D tranny
Push button 4x4
32x12.50x15 Maxxis mudders
Push button 4x4
