I'm looking for any info on putting a 460 carb motor and a c6 in a 90 bronco. Such as the electric fuel pump in the tank, the electric transfer case, hooking up gauges to the 460, what about the drive shafts lenghts? Thanks for any info.
Eric
460 Motor Swap
Guest_broncocowboy90_*
, Dec 28 2003 09:40 AM
9 replies to this topic
#2 Guest_AMFPT_*
Posted 09 January 2004 - 09:36 PM
you might want to put a larger fuel pump on their to feed that big 460. also I would put an NP205 transfer case in their and get rid of that electronic case. you probably will need a different gauge for your thermostat. and im almost positive the drive shaft should be ok.
Posted 14 January 2004 - 09:47 AM
old topic, but what the hell...
You'll need to get a bunch of bolt-on pieces - frame perches, motor mounts, exhaust, radiator, all the engine accessories that came with the 460, a big block trans... all kinds of fun
It's been done several times, but it's not a drop-in swap
Posted 14 January 2004 - 11:13 AM
http://broncograveyard.com has all the conversion parts from the motor mounts to the headers you will need.
Make sure to add images of your truck to your personal photo album!!!
Posted 15 January 2004 - 02:00 PM
Heh, I know they help sponsor this site, so don't take this wrong, but not everyone has the money it takes, to buy parts at BGY's prices.
In all honesty, all the parts needed for this swap, can be found in junkyards
Posted 15 January 2004 - 02:16 PM
Actually even though JBG does help us out with lots of the traffic we get I try my hardest to not to be too biased.
I agree that you can find all of these parts in junk yards, I was just mentioning that JBG was an option. The prices on some of the L&L products that JBG has are quite expensive, I should have qualified my post with that info.
I'll crawl back into my cave now
Posted 15 January 2004 - 03:33 PM
I never did understand why L&L's prices were so high, but I think it's ridiculous, no matter who sells it.
http://performanceun...nginemount.html These prices are a little more reasonable, but don't offer anything for headers or engine accessories, since not everyone is able to buy a complete engine for their swap. Over the last several months, I've SLOWLY been working on making accesory brackets for these swaps, since I really don't like mine at the bottom of the engine - that's how it came stock - and would rather everything - York air compressor, PS pump, alt - be above the centerline of the engine
#9 Guest_Breeze_*
Posted 14 February 2004 - 11:41 AM
Engine Swap 351/302 to 460 in a 90 Fullsize/Bronco (prices are approx, and assume you have a donor 460/C6 Trans)
Engine Swap Mounts $120 (JBGY)
Headers (83-87 F-series 4x4, non-EFI) $140 (Summit)
Oil Pan& Pickup (Ford) $150 (I think, cant find my notes)
Pulley/Bracket Kit (March) $850 (Personally, I would modify/adapt stock parts, but thats your choice)
Pressure Regulator (summit) $100 (allows use of Hi-pressure elec pump with Carb)
Roughly $1360, not including revamping the driveshafts (unless you have a long output shaft C6)
For the gauges you will need the proper sending units oil & temp (they can come off the old motor)
The Electric T-case will operate as before
Posted 14 February 2004 - 10:40 PM
Right away, $950 can be cut from that budget... donor engine would have it's own belts, pulleys and brackets, and there's no need for a pressure regulator, when the stock fuel pump would still be bolted onto the engine. However, if that person was insistent on using the Bronco's stock fuel pump, then I would agree on the pressure regulator.
Aside from the motor and trans mounts, the rest can be had either used, or on ebay for fairly reasonable prices
But I notice this character hasn't been back to comment on this, so who knows what happened
