shifter play
8 replies to this topic
#1 mike s
mike s
  • 3 posts
Posted 03 May 2009 - 02:26 PM
Have slack in column shifter in 95 ford f-150. Is this a hard problem to fix? Will go in gear but with a lot of play.
#2 lostin90s
lostin90s
    old part is good part s
  • PipPipPipPipPip
  • 144 posts
  • Interests:Wrecking yards , my kids , places with no cell phone service, and Centurion F150 crew cabs
Posted 05 May 2009 - 01:28 PM
There r a couple thing that will do this.
Remove upper and bottom cover . And see if bolts r just loose in the "U Bolt holding it in place .(this is common to happen ) You can unbolt and drop steering column to seat to work on it .
The other is the shift tube itself worn . And they can break on you .
Both r not hard to do . Common tools . tho there may be some torx screws to deal with its been awhile .
The last shift tube I bought I got at dealer. But they r oN eBAy and I 'm told in after market also .
good luck
Edited by lostin90s, 05 May 2009 - 01:33 PM.
Parts is parts
#3 Duke
Duke
  • 8 posts
Posted 10 May 2009 - 04:57 AM
You can also adjust the tension on the shift cable. This connects the shifter to the transmission. Most repair manuals, such as Haynes, have an in depth process of adjusting the cable.
#4 lostin90s
lostin90s
  • PipPipPipPipPip
  • 144 posts
Posted 24 May 2009 - 04:09 PM
So what was found out?
Parts is parts
#5 mike s
mike s
  • 3 posts
Posted 30 May 2009 - 05:42 AM
yes it was loose bolts thanks for the help sorry it took so long to reply been fishing thanks again to all help
#6 lostin90s
lostin90s
  • PipPipPipPipPip
  • 144 posts
Posted 30 May 2009 - 03:12 PM
No need to be sorry was just showing an interest . Glad it went ok . I broke the shift tube once and had to shift under dash for 3 days till it came in.
Parts is parts
#7 mike s
mike s
  • 3 posts
Posted 31 May 2009 - 01:02 PM
great and one more thing if you know about the codes on inside of door about tranny and rears?
#8 lostin90s
lostin90s
  • PipPipPipPipPip
  • 144 posts
Posted 31 May 2009 - 04:32 PM
There r basically 3 common rears in the F150 trucks
But there r 26 or so including all capacities and open or limited slip .
Common for the 3800 # equipped F150 include
Door tag #
12 is 2:73
17 3:31
18 3:08 see em with 300-6
19 3:55
Limited slip have letter number combo
H5 4:10
H7 3:31
H8 3:08
H9 3:55
But there r others depending on HD supension or F250 F350 ETC.
Tranny Codes r
M manual 5spd (mazda in F150)
E auto E40d
G Auto C6
U Auto 4R70w 4spd
C Manual 5 Spd ZF (F250 + trucks)
W 5spd HD manual
Motors Y= 4.9
N=5.0 302
H=5.8 351
R=5.8 351 Hipo
c=5.9 460
F= 7.3 Di
Need anything else let me know I have stacks of this stuff I printed off I just have to dig .
Edited by lostin90s, 31 May 2009 - 04:47 PM.
Parts is parts
#9 lostin90s
lostin90s
  • PipPipPipPipPip
  • 144 posts
Posted 31 May 2009 - 04:33 PM
The rears r 8.8 in back and dana 44 in front .
Edited by lostin90s, 31 May 2009 - 04:50 PM.
Parts is parts
