Hello All,
I have just bought a 1990 ford f-150,5.8 motor with a e40d transmission.This is our daily driver for the wife.Our problem is that when she sits in the truck during her lunch hour she likes to listen to the radio.Well when she turns the key to the accessory position the radio does not work or anything else in accessory position.I checked all the fuses and they are good.Is there some adjustment in the column to fix this or do I need to buy a new ignition switch?Right now she leaves the key in the run position which puts more drain on the battery and everything else.Thanks Rick
ignition switch
greyhound
, Jun 17 2009 06:12 PM
