keeping the truck running
Paulie6909
, Jun 17 2009 06:13 PM
15 replies to this topic
Posted 18 June 2009 - 01:01 PM
How old is carb? the idle speed could be in need of adjustment, choke sticking, or a vacuum leak at carb, intake manifold, or vacuum hoses. have you changed fuel filter or fuel pump?
i changed the fuel filter and the choke is workin fine...when i first goto start it, i push the pedal to the floor and let it up....the choke opens up about 1/8in -1/4in so thats fine...it just shuts off after running for 20mins
Posted 18 June 2009 - 07:32 PM
if it was the solenoid, the engine would not rotate, so you can probably rule that out since the engine starts anyway. the carb maybe flooded, has it been rebuilt lately? Also this may not be it but has the air filter been changed because there may not be sufficient enough air reaching carb after the choke opens up. (I think I maybe way off on the last suggestion)
Edited by bronc76, 18 June 2009 - 07:34 PM.
#15
Posted 25 June 2009 - 05:53 PM
what yearare we talking about? i had an 84 f250 with a 351 w that did the same thing. i changed the solenoid and the starter and i was on my way... good luck!alright will do...thanks for all the tips on what to check...ill get onto the timing and changing the plugs tomorrow
