its not the original motor. it had a 351w in it before. Guy that i got it from had said that it was changed to a 460. Is there any other ways to check if it is a 460?
460ic? i dont know?
ford_JCH
, Jul 05 2009 01:37 PM
4 replies to this topic
Posted 06 July 2009 - 07:00 AM
You can can get the casting number off the block or if it has the orginal valve cover .The data sticker could still be on it.
1985 Bronco 427 small block
C-6 with a 208 transfer
33x12.50-15 all terrain tires
Stock 5.8 with E40D tranny
Push button 4x4
32x12.50x15 Maxxis mudders
Push button 4x4
Posted 20 July 2009 - 10:41 AM
hey bud, you might try to find more info. at 460ford.com these guys there are bbf enthusiasts and you will most likely get answers quicker. good luck!ok i cheked and it is a 460, but i have no power at all. it has a 4 barell edelbrock carb.
Edited by foul al, 20 July 2009 - 10:43 AM.
