Cooling
Well for starters the truck has a 351M. The first thing I want to do is fix
the cooling system. My question is the fan assembly. Can anyone tell
me or show me a picture of the proper fan. What�s the proper fan size?
Do I need a spacer? If so how big? What about the radiator. Is it
"bigger the better" necessarily the right thing to do? I see LMC truck has
a 24 1/4 X 26 3/8 3 row or should I get the 19 1/4 X 26 3/8 4 row?
I will also need a shroud.....
i just want the best cooling for this truck.
Transmisison cooler.
how hard is it to hook one up? i would like to install one for sure.
powersteering
The power steering cooler is not connected. can i use the same cooler
as an aftermarket transmission cooler. or should i just run a new steel line.
thats just the tip of the iceburg.
couple of problems dont know where to start.
400M
, Sep 20 2009 06:07 AM
Posted 20 September 2009 - 08:38 AM
The fan with clutch on mine is 19 1/4" width. I dont have any spacers on mine as far as I can remember. Are you running air? Towing? I installed a trans cooler on my Bronco when I had my tranny rebuilt. Installs in front of radiator, just tap into cooler lines that run to tranny, not hard to install.
