i want to set up a 12 volt fuse block. basically it is a block with 6 points to hook up
looped wire terminals. it also has 6 grounding points. here is a link,
http://home.comcast....ck0/fuseblk.JPG
it can be used to hook up all my gauges and what ever else i need 12 volts for.
i basically want to run 12 volts hot when on and starting to a relay. then go straight
from the battery - to the other side of relay - to the 12 volt fuse block.
i need to know wher eto get the 12 volt source to trigger the relay.
thanks
12 volt source
400M
, Sep 20 2009 01:10 PM
8 replies to this topic
Posted 21 September 2009 - 03:57 AM
well this is my first ford ever. i did not know there is a solenoid for the battery.
have a pic of what i am looking for? my friend is coming out to give me a run
down of the engine bay components. i have to get a chiltons or similar book.
that sounds like a good spot to get my 12 volt source.
Thanks
Thanks
1979 Ford F-150 with a 351M regular Cab Rusted Short Bed.
in neeed of a good Short Bed. Help!!!
I know there is no such thing as a 400M, but mine has a modified CAM.
Posted 21 September 2009 - 11:03 AM
ok thats what i saw. and thought i would try to use.
i need to find a local ford nut that has patience for newbee's.
Thanks again! Bronc 76.
Edited by 400M, 21 September 2009 - 11:03 AM.
Posted 29 September 2009 - 03:48 AM
ok i looked at the starter solenoid. there are 4 connection points.
one for battery.
the opposite side goes to starter.
the middle 2? i have no clue?
i guess one comes from the ignition?
the other i dont know.
please let me know if you could.
Thanks
one for battery.
Thanks
Posted 01 October 2009 - 06:13 PM
to get power with ignition on only you need to run the power from the key switch power out wire. i dotn know which that is i am not a dentside guy.
