steering conversion
Posted 09 December 2009 - 12:51 PM
Posted 11 December 2009 - 08:14 AM
nah-i'm not so sure that's right krafty. i've read a related article on it somewhere, but can't for the life of me seem to find it again. you may be right, but...i'm still looking for another opinion. thanks though, and if you are right, my apologies.you'll have to swap out the steering column from one in a scrap yard that was a manual on the floor.
Posted 27 December 2009 - 04:04 PM
but as far as I know your problem lies with the 3 in the tree shifter. I never knew ford to use the 3 in the tree with a 4x4, so more than likely it will not work. any modification would pretty much have to be done with the coloum out of the truck, and swapped with parts from a either an auto shifter coloum or a manual coloumn
either way you need the other coloum to finish the job, if you can save your 3 on the tree shifter it is worth lots of money to certain people at swap meets.
Posted 28 December 2009 - 04:39 PM
you were right krafty, thanks. bought one for $100. thanks for the info about the shifter column, didn't know it was worth much more than a regular column.no worries you do what you have to do,
Posted 19 February 2010 - 10:11 PM
Posted 16 March 2010 - 08:20 PM
