Edited by redneckboy1988, 28 December 2009 - 07:20 PM.
:(( i need to know whats wrong with my 1986 f150
Posted 28 December 2009 - 07:19 PM
Posted 28 December 2009 - 09:04 PM
nosir, the driveshaft never did break. it could possibly be warped. but i cant find a driveshaft in a junkyard nowheres! and wouldnt that ruin your transfer case if you ran it in 4wd all the time?When you said that it did not quit slapping, did the shaft break again? The shaft maybe out-of-balance. If its 4wd, you can run without the rear shaft to see if the problem is still the rear end without the shaft.
Posted 29 December 2009 - 06:31 AM
Could be your gas tank, have you checked your straps?
I had mine fall off while i was riding down the road. Just put 3/4 of a tank in her. was soo lucky i didn't blow up.
Also, you can run it in four wheel drive w/o your rear driveshaft as long as your front u joints are good.
essentially, the transfer case is always running when it's in 2wheel high.
Posted 29 December 2009 - 12:38 PM
hmm i didnt know that. well they guy i traded it to wants 600 dollars back for it.. and it also needs the 4wd assembly in the left drivers side wheel.. =( idk where to get one of thoseCould be your gas tank, have you checked your straps?
Posted 29 December 2009 - 03:23 PM
Posted 29 December 2009 - 05:42 PM
i appreciate ya.. u dont know where i can find me a good truck for around the 5 to 6 hundred dollar range do ya?Want adds wrecking yards. The front axles for F150 been same since 80 so any should work . I get my parts from your area so I know there are back woods wrecking yards in the area . They have the older stuff. If no find let me know . I got several in my favorite yard .
