I also am having trouble with my 93 f150 E4OD tranny. But mine is different than other posts i've read on this topic.
When the vehicle is cold,(at start up ) when I put it in drive it does not engage untill I rev the engine several times. When it is warmed up it will go right in. It also seems to shift too soon into the higher gears. Has anyone you know had this problem ? Do you have any idea what's causing this ? I know this tranny is electronically controled, and I'm hoping I can change out some sensor or something, as that is a much cheaper repair than a new tranny. Thanks for any info .
E4OD troubles
HDCLASSIC
, Feb 15 2010 07:36 AM
4 replies to this topic
Posted 16 February 2010 - 03:15 AM
yo!
Try this first; a Self Test by BroncoJoe19
do the KOEO = Key On Engine Off portion first
& Remember to have engine @ Normal Operating Temperature before doing the KEY ON ENGINE RUNNING (KOER) portion
That will help w a bad sensor or wiring, etc. repair
Thanks to All Who Serve
Posted 16 February 2010 - 03:25 PM
yo!
Posted 17 February 2010 - 09:26 AM
yw!
Post any Codes found here.
Or look up some such as the TPS here; in my SITE @ http://www.broncolin...x.php?index=118
Possible causes may be the Throttle Position Sensor (TPS)
FAILURE SYMPTOMS
Hesitation, tip in surge, engine pinging,
no torque converter lockup.
"Check Engine" light on.
or:
Manual Lever Position/Transmission Range (MLP/TR) Sensor
As of 1994, the Neutral Safety Switch or Neutral Drive Switch (NDS) is referred to as a Manual Lever Position Sensor (MLPS) or Transmission Range (TR) Sensor.
; "E4OD Nagging Neutral Nonsense & Pinpoint Test, Manual Manual Lever Position (MLPS) also called Transmission Range (TR) Sensor. Some of the problems the MLPS can cause are wrong gear starts, TCC hunting, no 4th gear, engine stalling, high or erratic line pressure & a sudden neutral condition; The negative lead of the multimeter should be placed at the MLPS signal-return ground terminal at the MLPS...This sensor is responsible for more malfunctions than any other sensor in the sys- tem, and the kicker is that it seldom stores a code 67 or 634." Source: by Pete L at transonline.com
Water Intrusion of MLP/TR Sensor TSB 95-2-12 by Ford for 89-94
01/30/95
TRANSMISSION - E40D - DIAGNOSTIC TROUBLE CODES - WATER INTRUSION OF THE MLP/TR SENSOR
TRANSMISSION - E40D - POSSIBLE WATER INTRUSION INTO THE MLP/TR SENSOR CAUSING SHIFT CONCERNS AND/OR HARSH ENGAGEMENT CONCERNS
TRANSMISSlON - E40D - SHIFT CONCERNS AND/OR HARSH ENGAGEMENT CONCERNS DUE TO WATER INTRUSION OF THE MLP/TR SENSOR
1989-94 BRONCO, ECONOLINE, F-150-350 SERIES, F-47, F-53, F-59
ISSUE: Some vehicles may exhibit a shift concern and/or a harsh engagement concern due to water intrusion into the MLP/TR sensor and vehicle harness. There may also be a number of different DTC's along with those concerns.
ACTION: Replace the MLP/TR sensor and vehicle harness connector if signs of water penetration are evident. Refer to the following for service details.
SERVICE PROCEDURE
1. Verify the customer concern.
2. Perform normal on-board diagnostics.
3. Inspect the MLP/TR sensor for signs of water contamination.
4. If water penetration is present and/or DTC's have been set, replace the MLP/TR sensor and the vehicle harness connector with the TR Sensor Service Kit (F5TZ-7A247-A).
The TR Service Kit contains:
One (1) TR Sensor
One (1) Connector Assembly
One (1) "Red" Pin Separator Plate
One (1) 6-Pin Grommet
One (1) 8-Pin Grommet
One (1) 7-Pin Grommet
One (1) Instruction Sheet
PART NUMBER PART NAME
F5TZ-7A247-A TR Sensor Service Kit
OTHER APPLICABLE ARTICLES: NONE
WARRANTY STATUS: Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage For 1992-94 Models, Basic Warranty Coverage For All Other Model Years
OPERATION DESCRIPTION TIME 950212A Perform Electronic 2.0 Hrs.
Transmission Diagnostics, Replace MLP/TR Sensor
DEALER CODING BASIC PART NO. CONDITION CODE 7F293 08
FAILURE SYMPTOMS
or:
01/30/95
SERVICE PROCEDURE
One (1) TR Sensor
