continuous memory code 95 ???
Posted 16 February 2010 - 07:47 PM
Posted 17 February 2010 - 08:48 AM
hello, more questions for anybody that might be able to help. i pulled codes on my truck (1992 F250 7.5L) just to see if it said anything, i dont have a check engine light on or anything, the truck runs good and it passed the key on engine off test. then it showed a continuous memory code "95" the description in my book says "fuel pump secondary circuit failure<em dash> PCM to ground" and i also found this online for the same code "Fuel pump: open, bad ground or always on - Power / Fuel Pump Circuits" as far as i know the fuel pumps are working fine, it runs good on both tanks with no problems, but i am only getting 10 mpg on the freeway or around town. im running empty(no weight in the bed)in O/D with stock tires, no lift, K&N cold air kit, throttle body spacer, high flow muffler and 3 inch pipe from the gutted out cat back. just wondering if anybody has had this code and what they did to fix it, and if that could be part of my mpg problem. i understand that it is a big block but my older 460's that were carborated got around 14 to as good as 16 mpg. thanks for the info in advance!
yo!
This Code is complicated, but not as bad as an ICM failure.
A really quick and no $ test is to swap the Horn Relay for the FP relay
(& the EEC Power Relay could be secondary problem if intermittent due to corrosion or wiring or connector problems)
Horn & FP Relays (and EEC #1) are in da Power Distribution Box (PDB); here is the PDB Diagram in a 96, similar to a 92 (check da Diagram on your PDB's cover (inside);
http://www.supermoto...ry/media/533918
the PDB is Located under the hood on the drivers side fenderwell, behind the stock air cleaner location.
See Relay #3; you can swap it temp w/da FP relay #2 to verify if it is good; check for corrosion in socket...could be other (intermittent) problems along ckt.
Source: by Ford via Roadkill (The Beast) at SuperMotors.net
btw did you do both KOEO & KOER tests w the engine at norm op temps for the latter?
edit; this MB now won't load the Thumbnail Images !!! so I posted the URL
will bbl
Edited by miesk5, 17 February 2010 - 08:50 AM.
Thanks to All Who Serve
Posted 18 February 2010 - 05:54 PM
Posted 20 February 2010 - 08:26 AM
Yeah, corrosion is a primary concern in connectors, grounds, cable and cable/wire Strands (inside a terminal/lug or connector where it can't be Visually seen well)
GL!
Edited by miesk5, 20 February 2010 - 08:26 AM.
